Example Datasets
Posted: Tue Apr 26, 2022 2:33 pm
by gieschef
Attached a Zip-file with three EQX files and a quick description of what is contained.
Please feel free to post your feedback and possible challenges.
Re: Example Datasets
Posted: Thu Nov 09, 2023 12:19 pm
by Kate
Can you help please with how to define a 3D IRTRACC with radius calibration using the v1.6 XSD ? The problem is I do not see any definition of the equation for when the units are "mm" only mV or LSB.
Attached is my formula for the IRTRACC Radius Cal ...
Thank you
Posted: Tue Nov 28, 2023 1:49 pm
by Oliver Schnaus
The Zero-Int [mm] can be divided by the Cal.factor [mm/V lin] to obtain the Zero-Int [V lin]. Multiply with 1000 to get it in [mV lin], which is required in Sensitivity3 of the EQX.
The sensitivity needs to be calculated from "mm/V lin" to "mV lin/mm" for the Sensitivity element of the EQX.
