Attached you find a first proposal for a new Related Electronic Document
summarizing the recommendation for Active Safety Tests.
RED F - Active Safety Recommendation - Proposal
- ISO_TS13499_RED_F_20210412.pdf
- first proposal of RED F
- (916.77 KiB) Downloaded 1842 times
Re: RED F - Active Safety Recommendation - Proposal
An updated version of the RED F proposal:
- ISO_TS13499_RED_F_20210623.pdf
- updated proposal
- (932.37 KiB) Downloaded 1741 times
here is an update of the proposal for RED F:
here is an update of the proposal for RED F: I have added the results from the following discussions to this document: Best regards,
please review this new draft of RED F: This version contains all MME attributes which are required for Euro NCAP CA-004.
Topics for discussion are:
- Shall tuples for a Shape contain all points from each side or is each point unique and can only be contained by one shape definition? (e.g.: is the left corner of the vehicle part of front shape and left side shape or only in one of theses shapes)?
- Do we need additional attributes for given speeds in km/h or shall these only be added in for viability in "subtype of the test"
- Is a detailed "Name of test object X" for targets necessary as this is given by the main location in ISO code (see "5.1.1.3 Main Locations for Vulnerable Road Users")
